Johno Posted October 15, 2008 Report Posted October 15, 2008 (edited) Hi all, I'm pulling out my old 4ac engine and putting a 4age bigport in. I am in the stage right now of pulling everything out and labeling wires, hoses, fuel lines and thinga-ma-jigs. I wanted to know what a few things are called.. Any help would be appreciated greatly, Cheers, Johno :P Edited October 15, 2008 by Johno Quote
Bowler Posted October 15, 2008 Report Posted October 15, 2008 (edited) D is the charcole canister.... the others...not too sure...where to the wires lead on c? is f on a water outlet? if it is, it'd be a water temp sender Edited October 15, 2008 by Bowler Quote
Johno Posted October 15, 2008 Author Report Posted October 15, 2008 D is the charcole canister....the others...not too sure...where to the wires lead on c? is f on a water outlet? if it is, it'd be a water temp sender F = I don't think its water temp cos i already found that sensor on the thermostat housing. D= Is that where all the pollution and soot goes? C= I think comes from the battery and powers the loom to go inside the cabin for the fuse box. E= I would like to know what "e" is so i can label the green plug. A+B= Not too fussed with them 2, I think they are just some vacuum thingo. Sounding like algebra here.. :P Quote
Trev Posted October 15, 2008 Report Posted October 15, 2008 F = I don't think its water temp cos i already found that sensor on the thermostat housing.D= Is that where all the pollution and soot goes? C= I think comes from the battery and powers the loom to go inside the cabin for the fuse box. E= I would like to know what "e" is so i can label the green plug. A+B= Not too fussed with them 2, I think they are just some vacuum thingo. Sounding like algebra here.. :P F - Is the temp sender for the guage, The one on the thermostat housing is the fan switch. D - Yes, It returns fuel vapours back to the tank. C - can't remember which one but it goes to the starter, the alternator or the dizzy (I don't do alot on the single cam 82's) E - Pretty sure that is the purge valve for the charcoal can. A & B is for the a/c idle up. Quote
