also i just checked... it appears that winke55 is correct .. i am definately not a man..... either that or its reeeeaaaallly cold :bash:
If you need a 2nd opinion i will come to you :(
If you think it's definitely lifters, I'd try a product called "Wynn's engine tune up". I got put onto it by a mechanic and it shut up the noisy lifters in a mates falcon really well. It'll help clean off the gunk around the lifters and let them move freely again. :bash:
I'd say it is probably the timing chain.
To check if it is the timing chain, put a timing light on the motor while it is at idle. If the timing chain is good the timing marks will be steady. If the chain is badly stretched, the timing marks will be inconsistent, and wander back and forth.
Edited by Felix
