November 9, 200818 yr comment_288464 are the ke55 and ke70 5spd extension housings interchangable? if not are gears interchangable? cheers Report
November 9, 200818 yr comment_288477 Yeah extension housing are interchangeable. You starting to push the limits of K50's already Sash? Start hunting for a K-T!!! :y: Report
November 9, 200818 yr Author comment_288612 i should simon but its all money at the end of the day and money i don't have :y: so its back to the non trusty old k50 :D Report
November 10, 200818 yr comment_288664 just out of interest how much power do you need to be putting out to start smashing k boxes reliably? and how much do the k-t bellhouseings go for? Edited November 10, 200818 yr by DearmanKE Report
November 10, 200818 yr comment_288676 They'll put up with most things an NA K motor will throw at them if you don't drive like a rock ape. Report
November 10, 200818 yr comment_288680 what if i drive like a rock ape at times(some track use planned) and looking at about 60rwkw(hopeing lol) sc12 4k Report
November 10, 200818 yr comment_288685 You'll change the occasional box, but not each time you go out. I had a K40 in my old rally car with the 3K, and I only went through a couple. It was putting out figures (albeit NA) at about what you're quoting. Report
November 10, 200818 yr comment_288736 I smashed my standard gearbox in my corolla blew second gear and done major cog damage to the other gears. so i take it easy until i upgrade. but i am running about 88rwkw with the turbo on the 5k.. -Gerard Report
November 14, 200818 yr comment_290084 Ive heard K40's are stronger than K50's. If this is so, does anyone know what they'll take over the K40? Report
