November 14, 200818 yr comment_290051 gday all.... i'm new to the 7afe engine.... what sort of mods could be useful on this engine.... i have a 2" or 2 1/4" cat back and a pod with custom piping.... also anyone got a read up on how to build a 7AGE???? cheers rhys Report
November 14, 200818 yr comment_290063 this link should give you a rough idea on how to build a 7age >>>4age to 7age conversion Report
November 14, 200818 yr comment_290066 so you end up with 8.8:1 compression without a head skim? mmmm lol @ "i never thought id say this but torque really is very exciting too on the street adding a whole new dimension to the corolla!" gee, who'd have thunk it? Report
November 15, 200818 yr comment_290160 so you end up with 8.8:1 compression without a head skim? mmmm lol @ "i never thought id say this but torque really is very exciting too on the street adding a whole new dimension to the corolla!" gee, who'd have thunk it? this guy just slapped the 4a head on to the 7a block, without changing anything else really, plus like i said it was a "rough guide". Report
November 16, 200818 yr comment_290484 you fit the 4age pistons as well, that solves that problem. Report
November 16, 200818 yr comment_290564 gday all.... i'm new to the 7afe engine.... what sort of mods could be useful on this engine.... i have a 2" or 2 1/4" cat back and a pod with custom piping.... You've done just about all you can without spending heaps of money.....headwork can open it up a little bit, but combined with a bigger throttle body and you'll probably need a piggy-back like an eManage to fix up the maps. Report
November 17, 200818 yr Author comment_290810 yeah i need to find the mixture screw cause after i put the pod on, it has leaned out too much i think.... Report
November 17, 200818 yr comment_290875 yeah i need to find the mixture screw cause after i put the pod on, it has leaned out too much i think.... No such thing as a mixture screw on an EFI car :) What makes you think it's leaned out? Report
November 18, 200818 yr Author comment_290984 bit of lag now at bottom end of revs.... but top end goes overrated.... anything over 3500 is a nice kick compared to before.... i had one on my laser efi, hmmm! Report
November 18, 200818 yr comment_291194 its probably your exhaust causing less backpressure at low RPM and yet flowing better at higher RPM. Report
November 18, 200818 yr comment_291210 i had one on my laser efi, hmmm! Ok then, _most_ EFI cars don't have one. It'd probably only be the older transition EFI cars that do, no need for them these days Report
November 19, 200818 yr Author comment_291482 its probably your exhaust causing less backpressure at low RPM and yet flowing better at higher RPM. well i would think a cat back 2" would cause that.... only started after pod went on hence my reasoning.... Report
November 19, 200818 yr comment_291524 pod would be sucking in warmer air than with the factory air-box setup. Report
November 20, 200818 yr comment_291544 pod would be sucking in warmer air than with the factory air-box setup. Which is why you put the pod behind the front bumper where the resonator normally goes, and fashion up (ie cable tie the spashguard open) a scoop for cold air Report
November 20, 200818 yr Author comment_291667 i have no holes anywhere to run a pipe for cold air intake.... Report
