5k - Solid Lifters
Where can you purchase solid lifters for the 5k engine?
Does the engine ever come out with standard fuel injection???
I have heard that few 5k engine actually have solid lifters stock, not the hydrolic lifters! Is this true?
If so, How can you tell???
( I'm new to this stuff ) :D
thanks to All.
ROLLAS 4EVA
  • Replies 56
  • Views 64k
lol even if its got hydro lifters theres still gonna be pushrods. But theres gonna be ajusters on the rockers if its got solid lifters. If your not planning frequent excursions to 8000rpm the hydros should be fine.
5k's did come out with SOLID lifters, but there really hard to find.
the only reason i know, i brought a 5k in NZ for my starlet and it had solid lifers.
we now run these in the rally car, they are genuine toyota not chev.
the part number does cross referance to another toyota engine which Australia gets.
yeah.....basically if you wanna convert to solids you find a chev solid lifter that is the same diametre and length....
then use the 4K rocker gear for adjustment.
and Datsun A12 pushrods.....
simple really
Edited by Xany
sounds like somebody already converted your starlet 5k to solids
rumor has it, you use holden red motor lifters and datsun a12 pushrods
all the holden lifters that my brother and i looked at were all hydro anyway....
we ended up using chev...which are solid.....i dunno i thought they would been the same..... holden = chev
Sounds like a job for Warwick and his extensive EPC :D
5k solid lifers aren't on the EPC, we had to go to the microfiche to find it, but it does exist.
still have the toyota packet they came in, somewhere!!
This probably sounds completely n00b.. but do u mean the screws on the rocker arm that contact the pushrods, that can be screwed in and out?
Meaning my 4KC has solid lifters?!
not on the epc???
thats odd, the epc dates back to before the intro of the 5k....
got any details as to what model its from etc?
some top secret info here, they cross reference to, wait for it
3F landcruiser. toyota part number is 13751-61020.
on the epc under 5k's it doesn't list it but on the microfsche it list 2 lifters and 1 is solid.
check it out.
your welcome.
Tony done a lot of seaching for the part number, we knew that the lifters were out there but never kept the orginal packets in NZ so it took several trips to toyota and about 6 new lifters but we finally found them again, now we have toyota lifter packets all around the garage and house so we'll never loose the part number again.
have done some searching.... it does list them on the epc for some 5k models...
km3# liteaces and km2# liteace..... general countries only (nz, oz, sa etc)
but of course you can't tell if they are solid or not from the epc
nice one for the data bank! :D
yeah the epc has got 2 listed but i'm sure that one is the hyd lifter and the other is an update for it.
you'll know you've found the right one buy the price, the soilds are like half the price.
they came out of a 1989 liteace KM3? but we needed the chassis number off it, so toyota told us before they could track it down, we never kept the chassis number.
so it ended up a long hard road to find them again.
i'd love to do a 7K, with solid lifters, upright kit etc, just to see what it'd be like.
f@$ken torque,
giddy up
Edited by TRD ke70
i rekcon i could get a 7k to pull 8 grand, but it's the torque that matters, the cam shaft is the key, as long as the head is flowed right.check out the cam chart i put up, there's a 4 20 grind we tried years ago, and we could pull 9 grand easierly, i know of a racing starlet that ran that cam and he had the ability to rev it to 10 grand, f@$ken nut's.
