Turbo For My 4kc
hi people,
i got a turbo from a bmw 335i, its a 1.5L turbo that runs from 3 exhaust ports
I'm planning to run 6 - 8 psi bog stock engine
carby on the inlet of the turbo
(10 pounds on fresh engine)
questions....
how long will it last before KABOOM
also i know i should decomp the engine, can i use a 3k bottom with a 4k head?
its on a budget
TURBO PICS
yoooohooo taz_rx where areee youuu
  • Replies 41
  • Views 12.2k
Wow that is small.
You're drawing through? Is that really a good idea?
Are you using an aftercooler?
And have you read the FAQ yet?
Apparently these shitty 4k's don't last long over 6-7psi.
Stolen from the FAQ:
Some general rules for forced induction on K motors are: don't go too big, and don't run lots of boost. A stock K motor can handle 6psi quite happily, at 8psi their life gets reduced noticeably, and they go bang pretty often at 10psi.
And 6psi really is jack-shit.
nah no intercooler,
yes i have read the FAQ
3kc head on 4k = high comp
how about 4k head on a 3k? low comp?
i think on 10psi with no intercooler I'm gonna have problems with dentonation/pinging
wheres raz_rx when you need him :P
nah no intercooler,
Just send him a PM :P
And this probably belongs in your project thread too :P
I think on 10 pound you're going to blow the shit out of your motor, not only problems with pinging.
Try shit like this on something decent, like an escort.
4k's are a bloody joke.
I'm planing to do the same thing but i got a exa turbo
and a small intercooler
There are a few guys on here running in the region of 20psi on 4k's and they are still running.
the turbo is sooo small i reckon a 4k will spool it at 1 grand :P
But at six grand shit will fly
this better not turn into a negative $hit fight, there'll be some warnings thrown around ... :P
Best of luck with the project, ill be interested to see how it goes :P
don't knockt the gyt 3k 4k 5k arbnt jokes ther some making round 170rwkw mark thats huge power from1 to 1.8l
iff built right they would fly !
mate your a joke if you think 10psi is going to blow the shit out of a 4k.
I have had a sc14 on a 4k running at 16 psi for a year now. So unless you have done it
don't diss it :P
good luck with the build mate if you build it the right way you could get any where upto
180kw
Edited by **chumps**
don't diss it :P
180kw
whats been done to the engine?
draw thru or blow thru? carb info
i think i read your topic about blowing away a supercharged stato LOL!
keep it tup
Bottom end was standed had a spacer plate made up,
ported head with draw thru twin 42 and a oil cooler and that on the
right tune made 100kw easy. ATM i am working on a 5k to drift with
its going to make 150kw safely, you just have to do things right in the first place
jesus :P
do 4k heads fit on 3k? (decomp the engine easier?)
