Re Gearbox T40 To 5k Corolla
Has anyone had any problems fitting a T40 gearbox to a 5K corolla motor.. The gearbox wont go in the last ten millimeters
sounds like you don't have the spacer that goes behind the engine? tried spinning the output shaft in 1st gear while pushing it in?
Are we to assume you have the K-T adaptor too? what engine did the T40 come off?
have the spacer fitted . in gear and spun output shaft it goes to dowles wont go any further. its like input shaft is touching the spigot bearing
t-40 came off 5k carina have k-t bellhousing hyd clutch
gearbox specs are 21spline input 22 spline output gear stick at back of extension housing
Id put it down to hitting the spigot bearing. Have you got vernier calipers? check the size of the gearbox spigot and the internal diameter of the bearing.
Wouldnt have a carina spigot bearing available?
checked spigot and shaft sizes all seem to be the same going to get a 2tg spigot thanks to everybody for your help
Spigot bearing is - 6001zz t and k boxes fit the same spigot bearings .Good to renew anyway. Especially if its been poked by the inputshaft.
Sounds to me like clutch isn`t centered and ingoing shaft is hitting spigot bearing due beeing pushed to the side by clutch
got the right spigot was new when motor fitted . took off pressure plate and clutch plate box went straight in . ithink your right tojo2. will realigh clutch thanks
