August 31, 200917 yr comment_370290 anybody ever driven a car with brake booster flex, and the horrible feeling brakes that go with it? (think holden rodeo) anybody know an engineering solution to the problem? reinforcing the booster somehow? a thicker smaller diameter booster? any ideas? Robert. Report
August 31, 200917 yr comment_370296 see ones that brace the master cylinder but never seen a booster flex only the firewall Report
August 31, 200917 yr Author comment_370306 next time you have an ra rodeo (or even an rc colorado or dmax i think) get someone to press hard on the brakes while you watch the side view of the master cylinder, it flexes about an inch (or more) at the booster. problem is the booster is too large and too soft.... not quite sure as to how to fix it as such. Robert. Report
August 31, 200917 yr comment_370313 which way does it flex? does it go sideways or up and down? or does the booster seem to compress? i have seen bracing that goes from the strut tower to the front of the master cylinder, but not sure if this would help you Report
August 31, 200917 yr comment_370319 I've got a cusco master cylinder brace on my AE86. It bolts to the strut tower and stops the master cylinder (and therefore the booster) moving forward. Report
August 31, 200917 yr Author comment_370324 that would be the go. the booster moves forward at least an inch. maybe I should look into something like that for those pesky vehicles that this is a problem with. Robert. Report
September 3, 200917 yr comment_371080 a brace from from the back of the booster where it bolts to the fire wall around to the front of it...? its a top veiw, blakc is booster, green cylinder (and little squares are bolts) red is the brace... just a thought. but if it is what you say it is then it must be dangerous and i can't see how it could be able to flex an inch then go back to its normal shape. Report
September 4, 200917 yr comment_371142 So the actual front face of the booster is flexing? Not the firewall? If you really don't like it, just weld a couple of fat ribs down the front of the booster. Pull it apart so you don't melt the guts. Or like felix said, get a hydraulic booster. Report
