October 5, 200917 yr comment_379111 well a while back when i was using gasket goop, got it all over my hands and didn't notice at the time, but now I've noticed there's dried gasket goop on the paint, gah.....anyone know how to get this stuff off? Thanks guys Report
October 5, 200917 yr comment_379139 Quite likely turps, which shouldn't affect the paintwork if you wash it off afterwards. Definately not meths. Phone the manufacturers tomorrow & ask their Tech Dept. Report
October 5, 200917 yr comment_379316 if the paint is glossy, you'll probably be able to rub/peel it off once it's dry. Even polish should take it off. Report
October 6, 200917 yr comment_379333 Yeah should just wipe off pretty easy if its a silicone bases goop. You need to use speacial fuel resistant goop when sealing up say a carby gasket, so if the goop you used isn't fuel resistant you might also be able to wipe it off easy with a rag soaked in petrol. :) Report
October 6, 200917 yr comment_379453 should rub off if ur paint work is worth worrying about :D Report
