October 15, 200917 yr comment_382321 Hey guys, just wanted to ask what carbi this is... as i have no idea. Is it any good? Or could i have something better on there? How much is mine worth? I think my engine mite have abit of head/cam work... as i bought a kinder surprise engine... previous owner had no idea what was done to the car. Anywayz cheers John Report
October 15, 200917 yr comment_382331 Look around the carb base. It should be stamped with the model number. Report
October 15, 200917 yr comment_382453 yep, Falcoon weber. Air filter is doing SFA btw with that hole in the corner. Its supposed to be for the tappet cover breather if you want to hook it up. :jamie: Report
October 17, 200917 yr comment_382750 that is NOT a falcon weber carburettor. that appears to be a DGV off an escort. Falcon weber is a ADM and has a diamond shape top for the air filter to bolt on to, and is much larger internally. should be written on the bottom of the carburettor somewhere, its probably going to say 32/36 DGV on it. Robert. Report
October 18, 200917 yr comment_383243 Actually you're half right.... It isn't a falcon weber, thinking one thing, typed another. The falcon ones have an oval shaped top not diamond... http://cgi.ebay.com.au/Ford-Falcon-XE-XF-W...=item35a44aac1c Report
October 19, 200917 yr comment_383329 yea it is a pretty good carb, i had a holley 180 on my worked 4k which is pretty much a shitter copy of the weber, make sure its tuned right Report
October 19, 200917 yr comment_383370 ahhh now I remember, a 34adm off a falcon has an oval hole on top, the dgv has the square/rectangle stepped hole like your carburettor, and the dhsa2 I had was a diamond shaped hole. Robert. Report
