Cop Bait Ke70
  • Replies 1.2k
  • Views 1m
  • My few days of Fails and learning curves   Ok so here goes.   Bought new master on Friday.     Ella came up Sat morning to help install and bleed. Installed fine, everything tight. Problem
  • B.L.Z.BUB
    B.L.Z.BUB
    Looks heaps better with just the racks gone :y:
  • you spelt LS7 wrong lol
Grab another wheel cylinder.
heard about the air in your brakes? did you bleed the master cylinder if you did replace it?
Just use a universal nut f@$ker, haha.
I did. Need to get the master off and rebleed it methinks.
But I can't find my 10mm. :bash:
Best off using a brake bleeder/vacuum pump on the brakes to bleed the master.
Just make one with a old bottle and some plastic line.
:hmm: stripped bolts, more problems is what I need.
Ill bench bleed it tomorrow. If that fails I'll take it to a shop. I'm over it.
just get ya misso to sit in the car pump the pedal and you bleed it peice of pie mate :y: , get her to take 5mins to help ya out :laff: :P
I make my brother do it for me all the time and he hates it :laff:
There is more to it than that mate. Something is awry. The lines are bled but I still have no pedal. must be the master. Either the new one is f@$ked or just needs a bench bleed. Hope its the latter.
Gonna buy a flange nut spanner today and get the MC off and check it over.
reed if it doesn't work may i suggest a big sledge hammer undo all the nuts and bolts take the master cyl off, BELT THE F@$K out of it makes you feel better after you've bought a new master cyl from repco/autobarn/bursons/stupidly cheap.
That way after you have smashed the shit out of the old master you can replace with a brand new one and bleed it and be sweet,
May i suggest getting a full set of slave cyl's aswell as a master
