Just wondering what modifications (if any) i would have to do to put a KE55 'non' banjo diff into a ke20? Maybe its a salisbury?? I can't remember what they're called lol
Oh and will KE55 front struts bolt straight into KE20 :jamie:
I have done research but i haven't found much in regards to my questions.
Cheers fellas :y:
Mark :lolcry:
  • 4 weeks later...
A KE55 diff will fit, but it has different spring centres and different shocker mounts. I used a KE55 diff in my rally car with the KE55 springs and shackles. I just had to get urethane bushes made up. I also made shocker mounts for the diff, which mounted off the U bolts.
KE55 struts and way to big (diameter) to fit in to the tower.
so the diff that center comes out from the front of the hosuing is called a banjo? (no oil pan on the rear)
whats the normal diff called? with oil pan on the rear?
EvanG---
The normal one/borg warner is the one your talking about with the inspection plate on the back.
Thanks everyone.
