  • Replies 42
you buy a welder and some pieces of metal and some 2L ford rubbers and get to work
guys from toyotastarletracing yahoo group sell kits to put them into kp61 starlets, but that's it
I'm using 4A-C engine mounts out of an AE86 sprinter. They bolt up to the standard engine crossmember :n: If you can find some, good luck.
Yours bolt up? Interesting. Mine bolted up, if I didn't use any rubber bits (as in, metal engine mounts to engine crossmember mounts). With the rubber bits it didn't it anymore, which is why I moved the mounts out further.
I'll get some pics as soon as i can borrow a digi cam and show ya. Thats why i was wondering why everyone was using AE71/AE86 crossmembers cos i'm still using the standard one.
That'll be cool. Mine is a standard crossmember, just with the stock mounts moved further apart. I thought of using the AE71 engine crossmember too, but it was too much work to get to fit. Much easier to just modify the stock one.
I got pics of my engine mounts, but i can't upload them cos i havent made enough posts yet...
Damn that sucks!
Well, i didnt, someone else did. Makes it far easier to sit the engine in the engine bay without modding the cross-member.
yeah but that's not bolt in. how about we try NOT to mislead people, there's already enough bullshit on the net about cars as it is
Edited by Super Jamie
I'm using 4A-C engine mounts out of an AE86 sprinter. They bolt up to the standard engine crossmember 15-smile.gif If you can find some, good luck.
So this really should read "I'm using *modified* 4A-C engine mounts out of an AE86 sprinter"...
And it's much of a muchness really. Modify engine side of the mounts or modify the crossmember mounts. Both require cutting, both require welding, neither is really easier than the other I don't think...
Edited by demuire
I didnt know they WERE modified. You guys just confirmed it. As far as I was told, they were 4A mounts.
Sorry for misleading anyone, it wasnt intentional.
For future reference, the stock 4AC/4AGE mounts don't have any visible welds in them. One (drivers side) is a bit like a stalk and I believe is cast:
The other side (with the oil filter) is a folded sheet of steel:
