niggling things here and there, but the main one that's pissing me off is it's stalling on me when i put it into reverse.
it's a real bitch when i'm having to do those 10 point turns in these ʇ~~ɔy little streets around where i live while working.
i've checked the timing, it seems to be alright.. it is tending to idle roughly atm but i don't know what could be causing it.
i'm no efi wizard etc so i'm stuck with what it could be..
cheers, matt :D
  • Replies 30
i would be entertaining the idea that the century's engine is getting on 20 years old, running on crapper fuel here than it was ever intended to in japan, and can no longer maintain stock idle speed against the load of the highest transmission gear (reverse) against the torque converter
my bimmer was of similar vintage, and whenever i got it serviced, the mechanic would put it down to stock idle speed (750rpm or something) and it was a constantly-stalling piece of crap, even just clutching in at an intersection was enough to conk it out. i'd raise the stopper screw up till it sat on 950rpm and it never missed a beat
so perhaps just try raising the idle a couple hundred rpm?
really? hmm, my bimmer had mechanical injection (another shitty bosch product)
you could always try wedging something in the throttle stop just to see if i'm right, then either bend things to adjust it, or epoxy a washer in its place
could also be the gearbox is worn, or the converter. try changing the trans fluid
i'm one to exhaust all possible avenues of self-service torubleshooting before giving my money to a mechanic who'll just do them anyway and it might not fix a thing
Edited by Super Jamie
If there is one, it'll be on the throttle body. Actually, my sister-in-law's Honda Civic also has one, as does my Satria GTi, as did my Lancer GSR. So chances are, it has an idle control screw :D
it's got good ol toyota/denso efi etc
idle control screw eh, hmm i might see if i've got one
as for the codes, it's got the supermonitor, and it's flashing up codes, but i've no idea what they mean, can't find much info on the net...
ok so here's a call to mr. matt or mr. warwick.. could you identify my codes?
and nick, i so want my small chuckable car again as well, but it needs a crapload of stuff done to it and i've not the money atm to do it.. the whole vicious circle thing y'know? :D
Edited by NiteP]-[yRe
new instrument cluster, something in the electrics is screwed (none of the lights working etc.. fuses ok) rust that needs fixing, suspension bushes etc.. and thats just the stuff i can see..
sure, it's all fixable, but unfortunately it has to wait until i've got another FT job, as i'm spending $50 per week or so.. it's not that bad.. but i still don't have the outlay money atm for rolla :D
aanyhoo.. the C is mainly idling low when i select reverse.. sometimes it will stall, others it goes to stall then regains when i touch the loud pedal..
The error codes (for those that can help) are DIAG-06 and EFI-51
ah, i love cars =)
whats the build date on the car??
most of toyota's codes are the same through the ranges.
i'd be thinking it's the IAC(idle air control)
could allso be the engine temp sensor for the computer.
code 51 has to do with the A/C.
i'd reset the codes first just to make sure that it's not from pass events.
this is done by removing the EFI fuse under the bonnet for about 30 seconds and then refitting it.
then check the codes again.
if you still have problems let me know.
Dec '85
and it's Nippon Denso efi if that helps
i've removed fuses but it hasn't cleared the codes.. but i'll try it again..
i've got a few problems with the a/c but i know about those so heh
cheers :D
-[yRe,Jul 25 2005, 09:08 PM]
what's this code from?? DIAG-06
code 51 is from the A/C load circuit and is nothing to worry about.
Edited by TRD ke70
from my SuperMonitor display on the dashboard :unsure:
it flashes up all the codes, i've had a bunch of different ones come and go, mainly a/c and door ones, but they're no big deal... so, if 51 is a/c loading, why does it say EFI in front.. maybe it's a different set of codes for the century, and i can't find a list etc on the intarwebs
and after more testing, i've confirmed it's only doing the stall thing when in reverse, so i'm thinking it *could* be something gearboxy unfortunately... although, you know that's got me thinking about certain W5*'s and the words "sourcing a bellhousing" and "conversion" :o
am i evil?
yes i am!
:jamie:
