I'm looking to see what people have done about tail shafts for their conversions.
I have a ke55s with a 4age in it with an ae71 t-50 and a RA23 T-series diff. Celica drive shaft is the right length but the gearbox output different size.
does anyone know a good place the get a tail shaft made around brisbane or goldcoast?
OR is there something I can bolt in?
I'd try popping the uni joint out and see if you can interchange the yokes if the bearing diameters are the same. Might be a cheap quick fix if you're lucky.
