So is the part number in their catalogue wrong? Because the capacitor/condenser thay gave me is wrong too.
Man I wish I could open their catalogue on the web site. Ill give it another go.
And yeah I'll go electronic on the 5K (for some reason it has a points dizzy?).
Just need to make the 4K manageable until then.
Edited by blzbub666
Finally got the catalogue open. There are two part numbers
One for Bosch
And one for Bosch made for Nippondenso.
Bosch obviously make a replacement dizzy with different parts.
Pretty sure from memory the Bosch dizzys use GB534 points (same as most holdens). Can't remember the p/n for the Bosch condenser.
What dizzy do you have, Bosch or Nippondenso? Got a pic?
Yeah, that's the points set I need. I'll get them to replace the ones they gave me.
EDIT: Cheers Trevor I just stole that pic so I have something to show them.
Edited by blzbub666
If you use bosch points get the GB 752 points, There heaps better than the GB 534
They were designed for the XU1 and fit a bosch 3k / 4k dissy.
They have a higher spring pressure so less chance of point bounce.
I like to set the points to the lower limit, in the case of 3k about 16 thou, This gives the coil a greater charge time.
Cheers
Andy
Edited by Andy43
  • 8 months later...
Dang!... well now I am having the same problem!..
got dizzy cap, rotor and points - and they are all wrong!..
My dizzy is a lot bigger for some reason.
Does this mean its the nipon denso one? or the aftermarket Bosch one ?
and that said - what part numbers am i meant to be chasing down then??
try replacing the condenser.
yup, I've replaced the condenser thats attached to the dizzy.
although today I noticed one similar thats attached to the coil?
does anyone know if this is the same part?
