April 17, 201016 yr comment_430366 I'm in the midst of putting air conditioning from a ke70 into my ke55 (liftback) the problem is that we have a few plugs coming out of the evaporator (cooling unit) and we can't work out what the are for i found an old book that had the ke70 a/c wiring diagram but it is slightly different to my car if anyone has a wiring diagram for ke55 a/c or can help me it is much appreciated thanks, max Report
April 17, 201016 yr comment_430378 ill be over at my coupe tomorrow i can get some photos of the ac unit. what exactly do u want photos of? Report
April 17, 201016 yr comment_430381 i can help u out with a wiring diagram if u want coz I'm doing this too Report
April 18, 201016 yr Author comment_430494 we have connected the large plug to the amplifier and the plug with one blue wire with a white trace to the corresponding plug and i need to know what the: plug with one yellow wire with blue trace and one yellow wire with green trace goes to plug with two blue wires with white trace and two yellow wires with green trace goes to and the plug with one yellow wire with green trace and one white wire with blue trace goes to thanks, max Report
April 18, 201016 yr Author comment_430496 i can help u out with a wiring diagram if u want coz I'm doing this too that would be great if you could get a wiring diagram max Report
May 30, 201016 yr comment_441198 Still having dramas with this? I installed air-con in my liftback, was pretty straight forward... take some pics and I should be able to help :blinks: Report
May 30, 201016 yr Author comment_441218 nah its all good now, dad is liscenced so he has bits and pieces, so we got rid of the electrics and put a mechanical thermostat in Report
May 30, 201016 yr comment_441220 take a couple of pics, ill let you know as i done my conversion on saturday Report
June 1, 201016 yr Author comment_441563 Do you have this? Toyota_KE70_AC_Manual.pdf yes, but as i've said, ive removed all the electronics and converted it to a simple mechanical thermostat Report
