Ke50 - Fresh Paint!
new radiator hoses are in. engine bay degrease to come.
does anyone have a rough idea of what size spacer can be safely run before i need longer studs?
athankyou
tom
  • Replies 103
  • Views 40.9k
i had to buy new drum cylinders today.. as one is damaged inside..but $70 for a pair!!! :thumbsup:
i also replaced the shoes. and flushed the radiator... at least the rear brakes wernt as expensive as the slotted rotors!
also, can anyone help me with a KE50 windscreen rubber? if you know any corollas with the same windscreen, or if you know somewhere i could possibly get a custom made one?
cheers
tom
I'm not sure haha, thats what i was asking.
they have the same doors (the coupe that is) so its possible i suppose.
two door sedan :thumbsup: only ke15 and ke25 are coupes
good point.
it was something like that.
lucky has offered for me to test fit my cracked rubber in his ke55 to see how it fits, so ill see how that goes.
hey man that is coming along realy nicely. i am thinking of buying one of these myself and and fixing it up the white and black looks realy nice!
cheers
i have a spare if you want it.
only things its missing is; gearbox, dash, doors. and it has a bit of a smash up the back, and rust in the gaurds.
but other than that its good...ok so the only decent part is the motor, but hay. its very hands when your short on screws etc because its full of them still :D
i was thinking of painting the wheels black as well, heres a photochop i did;
Edited by Ke50
i hink you should leave the wheels gold they look way better and if i need spares i will send you a pm, I'm not sure what this one I'm getting is missing.
the spare will be gone by christmas, although i may just take off some parts as spares for the other car. but if you want something. make sure its before then :D
what about silver for the wheels? if i got new ones, performance wheels make them in 15x7.
umm na i think gold looks the bestand i will definatly let you know what i what i want off it. what do you plan on keeping off it?
anything that is on it at present (look above for parts missing) is going basically.
where are you located?
Seriously try windscreens obrien. I had to get the windscreen in the TA22 replaced and they had the windscreen AND rubbers in stock. Replaced it the next day if I remember correctly.
  • 4 weeks later...
well tom
u say the car is "alright"
I say its bloody awesome, u should be proud. I'm sure any rollaclub member would think it's wicked after seeing it fo real. I aspire to do what u have done.
Bring on the ke70
Dan :D
two door sedan :jamie: only ke15 and ke25 are coupes
Actually they are hardtops :D
As far as windscreen rubber...dunno if you still need one, but I know that KE3x and KE5x 4 door and 2 door are different, I have a stretched 4 door one on my 2 door at the moment, but I was lucky. So if anything will fit, it will be the 2 door one, as it will be on the same lean as a 2 door, due to the doors and door windows being the same.
