Rotormaster are north of the city.
MTQ have a few branches around there is one in dandenong but
prob a bit far from you.
Stu
If they're bush turbos do the rebuild yourself, unless the bearing has let go and the impeller has hit the housing you can normally get away without machining or balancing. should be under $100 a kit per turbo. Have a hunt online, I've read a few good articles over the years and it really didn't look too difficult.
