May 19, 201016 yr comment_438766 hey there rollaholics, I'm not too sure how crazy this may sound but ill ask anyway. i have a 91 cs(?) hatch coming into my possession. not even real sure if its an ok car or not to be honest. i've never known any1 with one. known of a few of the 80 models and they were good. but any way... i was looking over the web for some specs and stuff and come across the sr5. i thought wicked idea but i don't really like the body. so my question is.... what sort of shit am i going to get my self into if i was going to try and convert my little FWD watch to 4WD??? any ideas, pics or links would be great as reference and study. thanks all. Report
May 19, 201016 yr comment_438767 anything is possibly with the skills and some time, and a decent welder. are SR5's independant rear or live axel? Report
May 19, 201016 yr Author comment_438769 not sure excactly what the running gear is like in either car. hoping some one could let me know of this stuff lol Report
May 19, 201016 yr Author comment_438773 just found out that the sr5 is indepentent rear end. would that be a good thing or bad in this situation?? Report
May 19, 201016 yr comment_438774 good for the final product, either way you better be good at fabrication. You would need to chop out large sections of the srs body and swap them over to your corolla, then swap the whole driveline. Report
May 19, 201016 yr Author comment_438778 how extencive of a cut do u think? and I'm guessing already that i may need to woork on the center well? and if i am going to do a AWD conversion i would consider an engine change. would any option fit this set up??? Report
May 19, 201016 yr comment_438790 a whole rear floorpan inc sub frame and mounting points, a very serious job Report
May 19, 201016 yr Author comment_438794 :rolls: oooo that is a lot but i still think its worth looking at. just means i will have to look into it a bit harder than first thought. i knew it would be a big job. Report
May 20, 201016 yr comment_438803 if you are talking about using a AE95 4x4 wagon as donor , the rear set up is 5 link ( live axle) very similar (or the same) as a AE86 sprinter, the front set up is basically the same as a front drive AE9x series, just need a bigger tunnel and rear floor. i would think find a rusty 95 and pull it apart. Report
May 20, 201016 yr comment_438805 "and just fit a rear floor" you make it sound easy, familiar with cut'n'shuts? Report
May 20, 201016 yr comment_438808 "and just fit a rear floor" you make it sound easy, familiar with cut'n'shuts? ive not done anything like this before, but to me it seems that it may be easier to fabricate up new suspension mounting points (out of square section steel, almost like "tubed chassis" style) rather than try and combine 2 differnet floor plans together. you would need to re-arrange the rear end of the corolla to be able to physically fit the diff under there, which may involve fabricating up a whole new rear end. flooplan, mounts, rear suspension..the list goes on. and also make way for the tailshaft. a 5 link rear end has the beauty that so long as the mounting points are in the right place, then the diff will happily work in there so long as there is enough room. so you can do whatever you want to get the mounting points in the right place, and its not limited to combining floor plans. if you were trying to shoe-horn an IRS drive setup it may be some what more difficult, though i guess you could try and transplant the entire cradle in there (like the infamous s13 rear end into a sprinter) but you would still need some decent reinforcement on the mounting points. either way its going to be a pretty serious task, and its not just the fabrication that will be hard, actually working out where all the suspension geometry goes wont be eay (thats an entirely different subject, with hundreds of books around trying to explain it). the car may end up being 4wd at the end, but if it is all setup wrong, it will be pretty terrible to drive. Report
May 20, 201016 yr comment_438813 won't work with just making relocation points because as you say you will find the diff needs a lot more room. That's why you will find FWD cars almost always have a deeper floor. The way you could line up the rear end is to get a digital angle gauge on each of the suspension arms and then when your done check that their all the same, however swapping the whole floorpan should take care of that one. Your right though about it being a very serious project. Report
May 20, 201016 yr comment_438848 I was thinking about converting a ae82 corolla to a rear wheel drive and having a big HP engine in it but its a heck load of work.. :D I was going to cut n' shut the whole thing with ae71 parts. :rolls: Report
May 20, 201016 yr comment_438849 if you had the motivation, time and $$$ to succeed, you would end up with a funny looking WRX. Report
May 20, 201016 yr Author comment_438929 if you had the motivation, time and $$$ to succeed, you would end up with a funny looking WRX. id rather look at it as a mad rolla :rolls: Report
