August 26, 201016 yr comment_463108 dyno tune will obviously net you the best result. Just make sure you have a carby rising rate fpr. Malpassi seems to be the way to go for the carby's. I take it you'll be going blow through by the sounds of it? What engine you using? Also what turbo? Report
August 26, 201016 yr comment_463110 I'll be using a 4k with cam regrind, jetted carby, frontmount, t28 or similar and maybe water meth inj Report
August 26, 201016 yr comment_463145 Sounds good man. After anything in particular? Or just a fun car? Report
August 26, 201016 yr comment_463148 Nah dude just a bit of daily fun and the experience of doing it myself Report
August 30, 201016 yr comment_463982 What sort of performance could I expect from a ke70 with 100rwkw? 14s and a bit of a skatey ride when I want to pop the clutch? Report
August 30, 201016 yr Author comment_463987 You'd be looking at nearly the same power as a stock 4age just with boost, so when you did kick the clutch it'd definatly be some fun, but don't expect it to be like 4th gear munji's on a straight road in the dry, maybe in the wet but yeah it'll definately be a quickish ke70 Report
August 30, 201016 yr comment_464024 Cool as long as it's q bit of fun, I've had a few quick vls, one with 320rwkw manual and another 290rwkw transbraked auto so I know what 4th gear 100kmph+ burnouts are like :P Report
August 31, 201016 yr Author comment_464438 can somebody please explain the logic behind water/meth injection i don't get it what benifit other than (what i guess it is) cooling intake temp is there for it???? Like how would it benifit a boosted k motor??? Report
August 31, 201016 yr comment_464464 nothing special about a k motor http://en.wikipedia.org/wiki/Water_injection_%28engines%29 Report
September 2, 201016 yr comment_465083 So I'm not really familiar with carbied engines but how do you guys tune these things? Do you just change jet sizes until it doesn't flood or ping? What if I wanted to up the boost from say 8 to 12psi, would I have to change jets again? I'm guessing I'd only have to change the secondary? yeh drill the f@$kers out, but being a mechanical secondary, with the carby you will usually get a flat spot if you floor it down low as it clears itself up. Drill out the secondary till at peak power you have your target afr as everything under that will be rich...lol, Lock the dizzy and advance it till it makes peak torque, without water injection that would be a balance, with it should be cool I wish that i fitted it to my old car, would have been killer. might not have to change the jet with a boost up, just depends, and if you use 4k isn't there 2 types of pistons(aussie/jap), and one was weak as piss? cheers darren Report
September 2, 201016 yr comment_465085 can somebody please explain the logic behind water/meth injection i don't get it what benifit other than (what i guess it is) cooling intake temp is there for it???? Like how would it benifit a boosted k motor??? 1. being non crossflow head, everythings on the same side, they heatsoak like a mother f@$ker( what looks good on a dyno tune may not look good after a 30 minute thrash of "racing on a private airstrip", i had to pull 2 degrees of timing out of the whole map dyno tuned to stop detonation after hammering it time and time again up to 160km from a 60 km roll. Would be fine for one 1/4 mile run however. 2. the combustion chambers aren't all that flash as look like they would have lots of hotspots leading to detonation cheers darren Report
September 2, 201016 yr comment_465178 Cheers daz did u get my pm on Calais turbo regarding your old setup? Report
September 2, 201016 yr Author comment_465191 So it benefits the motor abit, mainly just to keep it cool? i wouldn't use it cause it just seems like a waste of time to me IMO, Report
September 2, 201016 yr comment_465193 So it benefits the motor abit, mainly just to keep it cool? i wouldn't use it cause it just seems like a waste of time to me IMO, oh its not a waste. its actually a pretty awesome idea. but if it screws up, your engine fills up with water, and you will bend something in a fairly catastrophic manor. and you need a fairly decent setup to make it work, wire it into your ECU as an auxilary, get your water pressure spot on, and your plumbing 100% perfect. my mate is doing it to his 12a turbo, he spent about $150 just on the nozzle. he is intending on injecting just before the turbo, which i guess helps keep turbine temps under control as well. though i wonder how the turbine blades like cutting through water... the other advantage other than cooling (though it sorta is cooling) is that it keeps the heat in the combustion, rather than losing it out the cylinder walls. greater efficiency thus more powers. it also keeps the inlet temps cooler, which increases the density of air = more power. though I'm not sure how it would go with a carby turbo setup, note sure i would be tooo keen on pumping water through a carby, but theres no reason why it shouldnt work.... Edited September 2, 201016 yr by ke70dave Report
