4k Weird Problems??
hey guys this goes out to all exhaust specalists!
just recently got a new exhaust right changed from my standard 1
the new system consists of
- 2" system
- Resonator
- SuperHi Flo Catback muffler
- Sports Exhaust with 3.5" chrome dump pipe
the car is acting VERY weird since ive got the new exhaust, when i am driving along and then i want to plant it/flog it/foot flat down lol, it will go
put put put and the revs will go low but then the car will slowly climb and go hard??
its like theres no power or horse power but the system should be making it better not worse?
any help would be great, the only problem i can think of is mabey the carby needs rejetting to suit the new system but yeh ??????????????????????
have you done any intake mods?
exhaust is free'd up. free up the intake for some more power
or mite be a lack of back pressure :jamie:
edit: lol cat back lol
Edited by Evan G
So it dies low down but then goes hard once the revs are up??
What carb and cam?? Stock??
Sounds like a lesson in why racing cars that only run from 5000rpm upwards run enormous exhausts...
Oh- and what exhaust manifold??
Edited by altezzaclub
yeh i was thinking back pressure 2 or the carby being jetted up to suit but no its as stock as a rock the 4k just the system at the moment, not sure on the manifold and yeh the 2" system is a bit big but this still shouldnt be happening?
yeh when you take off its like all its horse power is gone till about 3000 revs then she starts to pull??
so basically no torque what so ever.
2 inch is huge for a 4k. at least it should have a 1.5-1.75 inch end pipe for some restriction
nuh 2 " the whole way now i know its big but not enough to be doing this? what do use think
I think that is exactly what I'd expect from what you've done....
Spend about $4grand on the motor and it will run that exhaust beautifully, porting job, high compression, balance, twin Webers, extractors..
But bigger jets might cover it OK.
yeh i think ill get a cam grind and bigger carby hopefully ill sort the problem b4 the new engine
once again 'backpressure' has reared its ugly head into exhaust question.....
it is volume of air and the size of the pipe which changes the flow velocity of the gases.
in VERY general terms:
low volume of air + too little exhaust pipe = restricted gases = bad (stock exhaust)
low volume of air + small exhaust pipe = high gas velocity = good (an appropriately sized exhaust)
low volume of air + big exhaust pipe = low gas velocity = bad (what the OP may be experiencing)
higher volume of air + big exhaust pipe = high gas velocity = good (what you will get with a worked engine and an appropriately sized exhaust)
to the OP, did you tell the exhaust shop to put 2" on? or did he do it?
alternatively,
i was just reading about how a bigger exhaust can make a an engine run leaner, due to the fact that more air is able to get into the cylinder but the carby isnt tuned for it. so that could well be the problem also.
Edited by ke70dave
