ive got the cams out of my 4afe head but is there a special trick in getting the valve springs and the valves out
the little ring that holds the valve spring in place i can't undo and i don't know the tricks
is there a simple way or do i need a special tool
may seem a Noob question but this is the first toyota head ive ever pulled apart
thanks in advance
Harry
You sir, need one of these!
Its an overhead valve spring compressor.
Just ask Philbey how well it works as I sold him one not long ago and he swears by it.
Edited by Raven
There is a one handed item on the market that my cousin has, It will remove and insert collets with ease, I will get some info on it when I go to work, It really only takes about 30 seconds to remove valve springs from a 12 valve head.
http://www.toyotool.com/PURCHASE.htm
look here these are probs similar to what your cousin has trev.
i have one and it works great. watch the video! its on the homepage.
there is another brand i forget what brand that does the same thing and it close to half the price.
That's the one or same thing different brand, I have never used anything easier.
thanks alot fellas this has really helped me out does anybody in s.a have one i can buy or borrow or can i get one from an auto shop somewhere
i'll see what i can do.. my missus dad has my tool but i could get it off him by the wkend i reckon.. pm me.
Raven works in an auto parts shop. I'm sure he can hook you up with one as he did Philbey.
I've got the exact sucker Mick pictured. Yes it is a good piece of kit, much easier than others I've seen.
That one in the video is pretty cool! I wouldn't want to be trying it on a set of 300 pound race springs though.
It really is quite easy, you only compress the spring for a portion of a second and it works good on heavy duty valve springs, you can use it single handed on vg30 heads.
