November 20, 201213 yr comment_637175 caster makes everything better. the limiting factor is when your arms arnt strong enough to turn the wheel... Camber, depending on use and how much you care about your tyres on the road you shouldnt need any more then -3degrees but maybe 1.5 to 2 might be better on street stuff.. and with toe for street 2mm out is fine. track only car weve had v8 supercars around 10mm out sometimes but around 4-6mm out should do the trick zero or in will make it twitchy in a straight line. i ran like 8mm out on my ke70 at its last outing at winton. Report
December 21, 201213 yr comment_640753 so anyone been out to archerfield recently for drifts? Do they still run them? Report
December 22, 201213 yr comment_640762 Yeah, they still do it every Thursday. There is some event on today. Report
December 23, 201213 yr comment_640968 ok cool. Do they get a big turnout? do cops hang around much? Report
December 26, 201213 yr comment_641332 They get a few people and Archie is full of cops so they may drive by. Report
December 28, 201213 yr comment_641598 Where are you measuring from to get the numbers 2mm? Edge of the rim? I did my alignment with string lines and jut set the toe to zero. How will I benefit from more toe out? Edited December 29, 201213 yr by GREESR Report
December 29, 201213 yr comment_641688 Got friend to align it in his workshop. The toe out gives you that little bit better turn in. Which I really like. Report
