Setup Your Car For Drifting
caster makes everything better. the limiting factor is when your arms arnt strong enough to turn the wheel...
Camber, depending on use and how much you care about your tyres on the road you shouldnt need any more then -3degrees but maybe 1.5 to 2 might be better on street stuff..
and with toe for street 2mm out is fine. track only car weve had v8 supercars around 10mm out sometimes but around 4-6mm out should do the trick zero or in will make it twitchy in a straight line. i ran like 8mm out on my ke70 at its last outing at winton.
  • Replies 126
  • Views 106.1k
  • Helmet Fire extinguisher TRACK TIME
  • Undertaker_is_the_best
    seein as how i will soon enter this crazy but awsome world of driftin and i have been in the car with justin so i can vouch that from what he has done and i have watched it really comes to what he say
  • srry about the late reply this is the first time in a while i have had the chance to get onl;ine but yes, my car is an 82 ke70 5spd 4k the skyline seats are great! would definitely recomend them as an
so anyone been out to archerfield recently for drifts? Do they still run them?
ok cool. Do they get a big turnout? do cops hang around much?
Where are you measuring from to get the numbers 2mm? Edge of the rim? I did my alignment with string lines and jut set the toe to zero. How will I benefit from more toe out?
Edited by GREESR
Got friend to align it in his workshop. The toe out gives you that little bit better turn in. Which I really like.
