Ke70 Rim Offset
Before I start sorry if this has been covered I've typed into the search function but couldn't find. I'm looking at getting some new rims for my ke70 sedan with standard guards at the moment but will be flaring out bottom lip as in tech quide.
My question is will 15 x 8 +/- 4 fit under the guards with some stretch tires or hang out? The car is only a weekender but I don't really wanna be getting defected and asking for trouble.
Cheers for ya help
I put 14x7.5 0 offset on the front of my T18 and need the guards rolled, and same with 14x8 0 offset needs the guards rolled on the rear.
Yeah sorry guards will be rolled and flared as in tech article.
I got 15x8 0 offset on my ke70 with lowering springs all round and shorter shocks in the rear. Tyres rub on rear guards but thats only with the guards quickly bashed out I haven't got around to doing them properly but will be similar to the tech article you mentioned once done. Fronts OK at the moment but will need to come lower as I still have to make the front springs captive. Guards will have to come out quite a bit but I shouldn't have an issue once their done hope this helps.
FWIW:
14 x 8 -6 on the rear, obviously no tyres though. Guards are not flared, but have been 'pulled' out about 5mm. I'd imagine a +/- 0 offset would sit a fraction bit more in that that on a standard guard. You would NEED to have the inner lips of the guards folded/rolled up, but other than that I'd say you could get them to fit w/o massive flaring etc.
Edited by bLinded_
Sweet guys cheers for the help. Think I might go 15 x 8 -4 on front and 15 x 8 +4 on rear but I'll try on and see how they sit. Liking the picture above though looks sweet.
On KE70s wheels sit further in at the rear, so -4 all round is ok. Fronts are easier to roll/pull.
I have 15x8-4 all round, pokes a little
You do? Are they Watanabe's?! :D
I'm looking at superlights love them things. Selling original wantanabies to find but don't know what there worth???
Gee I'm not that rich seabiscuit haha
They are actually superlites
Alright so now next choice is tyres. I want some stretch, but was wondering what size and style/brand people suggest?
Don't get to much stretch, I had a sidewall collapse on Monday, was a 185/60 r14 on a 7.5" wide wheel, but then the tire was old and only had 35PSI in it. then I put a 195/60 on and still stretches a little but not too much.
LOL I was gunna run 195's on the 8 inch but after that think I may look into 205/40/15. Unless some1's had success with 195???
I'm running 195's now on my 8" as well, just get 195/50 if your using 15's it will be better because you will have smaller stiffer sidewall.
