Ra40 Or Ra 60 Brake/Strut Upgrade
Basically I'm looking at front strut and brake upgrade for my ke70 sedan, thats cheap (as in stuff i can get a upullit). Just a few questions i would like some answers on please. the RA 40 celica front struts are they same insert diametions of the ae86 and xt130. The RA40 lca are the same length of the xt130 correct? Also do the RA60 hubs and calipers bolt to the ra40 strut.
as in the ra 40 strut upgrade is unsafe?
why is it unsafe whats the best upgrade??
Cheap upgrade
XT130 Struts, and MX62 calipers and RA60 discs
Pajero Master Cylinder
New Brake Pad
what model pajero master cylinder do i use?
i have a set of what i can determine are ra40 struts, it has 260x21mm vented rotors with twin piston sumitomo calpipers that are running ra40/60/mx62 brake pads with ford corsair king springs. i never built this setup only found it in the ke35 i bought... what makes the ra40 setup unsafe?. the car has the ra40 lcas, steering knuckles and bolts straight into the strut tops
