Nissan X-Trail T31 Series
I have a T31 turbo diesel 5 speed auto. They have some problems with oil in the intake, (installed a oil catch can to fix) and Dpf blocking up ( had it removed and remapped ecu) . The diesel been good more torque than the petrol. Ive only heard of clutches in the manuals failing but I guess it depends on how you drive it!
Front Brake Caliper Bleeder Screw Help
In Melbourne most brake places still on holidays. There is a large selection online as well as speed bleeder screws, make it easy to bleed considering these. All I know is the bolt is 10mm but the thread,length and taper end size i'm not sure about.
Bled the stock brakes on my ke 35, I have noticed the front drivers side brake bleeder screw is seeping through the thread as it's not sealing properly. I removed it and cleaned it up as it was quite rusty, refitted it , re bled the system however still seeping. I want to try a new bleeder however the local car stores Repco, Bursons etc don't seem to stock any. I have seen a few on ebay however there are different sizes. Does anyone know the correct size/type I should be looking for? When I had it out I forgot to measure... Thanks
Ke35 Coupe What Engine?
20valve 4age will still require custom work.... what cost was the 13b conversion going to be?
- Oil Filter
- Genuine Te37 Levin
Shitbox Rally
great pics and perfect vehicle for the journey!
Ke70, True 1982 Timewarp. Check It Out!
the paint looks really great, excellent example of a ke70 and congrats on keeping it original... just needs wide wheels and drop it on it bump stops lol jk... on serious note would you consider widening the steel wheels? i think that would look great and still look original...
1967 Toyota Crown Ms47 Wagon
its good to see you saved her you don't see these often. can't believe it was at wreckers! definatly deserves to be fixed....
What Car Is Your Dream Drive?
4Age Into Ke30
been done to death, why not go turbo. regardless be prepared to spend some cash....
Joshs Ke36 Panelvan Project.
good job on the car came up great... diff looks shiny! 5 speed isnt much difference...
Setup Your Car For Drifting
drift bible is a good watch, using different types of vehicles using all the different techniques. silvias,mr2 and a ae86.... love how the ae86 is full throttle the whole time to get it going!
4K So Slow!
they are slow...manual conversion will improve it some what..... i have 2 ke35's one wth a 4age, other stock 3k 2 speed auto.... the difference is huge.. saying that k motors are bullet proof and very reliable ....
