ok quick update,
- haltech is in and wired
- had to drill and tap the snout on the throttle body to accomodate the bigger air temp sensor for the haltech.
- LS1 coils are mounted and wired.
- First half of exhaust is welded up, up to the diff.
- Cooler pipes are nearly done, throttle side done just gotta finish the turbo side.
- Tailshaft loop is done, tail shaft is in,
- rear end is completely welded up now
- radiator is on its way from just alloy radiators.
pics will be up soon
Gday mate,
first of the car looks like its coming around nicely. Secondly i am putting the convo pros on my ke30, my front rims are fine but do you have the exact size of your rear, including offset. I am about to order some from jegs.com.
Thanks mate.
:worship:
I am proud to see that my old wagon went to such a great new home.... :party:
Looking fantastic.
Keep the pic's rolling in coz i am enjoying seeing progress....Something i could never seem to get happening :bash:
pics!!
Ratchet shifter
Engine Bay
Rear end
Made these flanges for the exhaust on the mill at work
Half the exhaust
Haltech PS1000
Just some of the fittings for the fuel system
More to come during the week
Most of mine are push lock, never had a drip from one of them.
FYI - The straight are easy to fit into the hose. 90* and 45* ones ones the other hand are a bitch. I ended up with a bruise in the palm of my hand from doing them!!!
From what I can see majority of them are not straight either. And good to hear that the push on works just as good :)
Certainly do, if you've put one together you wouldn't doubt them.
Tips for beginners when putting them together - Soak the hose in some HOT water for a little while prior. It'll make the hose slightly more flexi. Also wiping a small amount of grease or dishwashing liquid around the fitting or end of the hose helps. :wink:
Also anybody thinking of using them - The fitting itslef isn't really any cheaper than a braided one, its the hose itself that can save you some coin.
yeah the guys at pirtek have told me what a shit they can be, and ive seen them done before.. the -6 ones arnt too bad to do, but the -10's are going to be the hard ones ... once i finish making the surge tank, ill start putting the fittings on the hoses..
