Ra40 5Spd In A Ke30
rolla_93
By that i'm guessing you mean w50? Which afaik may or may not be hydraulic. Being W series and not K series it's not a straight bolt in and bellhousings wont fit, and output shaft on the box is 99% likely to be a different pattern/ size to that on your driveshaft.
Easiest thing would be to get a box and compare.
Or Just look around for K50.
Cheers Jono
edit: other beat me to it :lolcry:
Edited by Jono.C
both my ra40s have had hydrolic clutchs... and they both had w55 box in them
Seems really odd to me, as every single ra40 manual I have ever seen features either a w50 or w40.
I know you need a liteace housing off an L series gearbox to make it work from memory. May as well use the liteace clutch too while you are there. Should be cable aswell.
Yeah RA40's had W40/50. are you sure your's were 55's? is the gearbox case steel or alloy.
And yes a W50 (in normal RA40 form) is hydraulic clutch, but as soon as you bolt the K-W bellhousing to it it becomes a cable operated box as the litace was still cable.
Edited by Taz_Rx
