September 29, 200521 yr comment_73789 As the title says, I'm asking what code it is. I know its KE2x, is it a 20 or a 25? Its a '73 sedan... How much do these go for, like a straight one? I know these are stupid questions. Report
September 29, 200521 yr comment_73799 If its a 73 Sedan, it should be a 2 door KE20. 4 Door KE20's weren't delivered in Australia, and I've only ever seen one. If it's a 4 door, it's a collectors item in Oz. 2 door coupe's are KE25's. A good straight one can be worth anywhere between $600 and $2500. Usuallt around the $1000 and $1200. Would need photos. Cheers R Report
September 29, 200521 yr comment_73811 yeah, no such thing as a 4 door ke25. anywhere as far as i know Report
September 29, 200521 yr comment_73824 i've only ever seen one 4 door ke20. Fook was there at the time, so i'm sure i wasn't seeing things. Report
September 29, 200521 yr comment_73826 they're around, i believe they came from some asian country where it's law that cars have to have 4 doors. same place the 4 door ke10s come from Report
September 29, 200521 yr comment_73834 same place the 4 door ke10s come from yep, seen a couple of them now. ever seen a datsun c30 1800 with a g18 motor? just like a datsun 1600 only bigger and better (has rack and pinion steering). a mate has one, was a south african import as far as we know. rarer than rocking horse shit. he was thinking of selling it, maybe i should buy it. Edited September 29, 200521 yr by Felix Report
September 29, 200521 yr comment_73863 i think you should let jon barr from japanese restorer magazine know about it, and stick to corollas that you can actually find parts for :hug: Report
September 30, 200521 yr comment_73951 Doh! My bad! I meant KE20! hahaha Usually the KE25-35 means the coupe and the KE20-30-50 is the sedan. Report
September 30, 200521 yr Author comment_74001 I'm guessing that the coupes are pillarless? Or is it just more of a slanted rear roofline? Report
September 30, 200521 yr comment_74004 Or is it just more of a slanted rear roofline? Correct. KE20 sedan: 02290055_vi.jpe Edited September 30, 200521 yr by Redwarf Report
September 30, 200521 yr Author comment_74026 Would I be correct in saying that the sedan does not have a pillar fuel filler, and the coupe does? Is that an easy way to 'diagnose' the car? Report
October 3, 200521 yr comment_74478 i usually tell them by the roof (ke20 is a couple of inches higher) and the vent in the rear quarter. they have massively different tail as well, the whole bootlid and tail lights are impossible to confuse by definition of car body shapes, a sedan has a full height side window to the top of the rear windscreen, a coupe side window starts to taper down before it reaches the rear screen line. you can see this very well in the pics rob posted this is a general design rule that applies to any car, not just corollas, not just two doors Report
October 3, 200521 yr comment_74495 by definition of car body shapes, a sedan has a full height side window to the top of the rear windscreen, a coupe side window starts to taper down before it reaches the rear screen line. That's one of the best descriptions I've heard. (seen) :D Report
