October 5, 200521 yr comment_74938 to undoe the bolt I just use a shifter, 2 flywheel bolts one upper engine - flywheel bolt. *Put a flywheel bolt through the hanger hole on the shifter into one bolt hole on the crank * Put another flywheel bolt diagonally across from the first one you put in. *Spin the shifter around so it's tight and place another bolt into the block up high for it to push on. Like this I find it easier to crack flywheel bolts then when the motors in of the car. Report
October 7, 200521 yr comment_75624 LOL , i love the put the shifter on it and hit the key , funny thing is even though we have all done it , not everyone would admit it......lol. If all else fails , grab your Big F@#$%g Hammer and give the bolt a good belt into the crank , just like your trying to Nail the ballencer on "so to speak" that way if some asshole has used Loctite on a previous job (and I'm guessing they must have) the shock helps to fracture the stuff. Worked for me heaps before , although if its a customers car better to wait until they are'nt around because hammers don't look all that professional. DyNo. Report
October 8, 200521 yr comment_75674 if you still can't get if off Teddy just bring it over, we have a rattle gun here that doesn't like bolts, it'll get it off no problem. Report
October 9, 200521 yr comment_75720 although if its a customers car better to wait until they are'nt around because hammers don't look all that professional hammers are plenty professional, and a required tool in a workshop attacking a customer's car with multigrips, however... Report
