Ae71 Hydro Clutch In A Ke55 Coupe
As the topic states, I'm curious as to whether I can fit an ae71 hydro pedalbox/ clutch into my ke55 coupe. Reason being is I want to run a w series box to deal with the power I'm going for and will probably have zero chance of finding a w series box with cable clutch setup... If this won't work any other ideas on making/ getting a hydro clutch to suit my 55 coupe.
Cheers, Jake.
No it will not fit ,well not with out a lot of stuffing around.Better off converting the 55 to hydo not that hard.
Thanks for that. Any idea how I would go about converting it to a hyrdo setup?
Cheers, Jake.
ill take a picture of mine, its really simple
Cheers man, really appreciate it!
Cheers, Jake.
Is that all there is to it? Where did you get the parts for it? I'm not sure what's needed, something like master cylinder and slave or something?
Cheers, Jake.
Cheers, Jake.
i didnt make it, it was in a shell i bought a while ago
well master cylinder will possibly be an ae71 or celica one have no idea
but your slave will obviously be a W series box slave
Cheers, Jake.
Just out of curiosity, what engine are you planning on running in front of the W-series box?
Heavily worked, twin charged 5K engine.
