It Wont Start!!! Hellp !
my ke 30 wont start ( when i turn the key i can hear the starter solinoid click, ie checked the cableing, adn the battery is fine.
what could it bee??
starter motor????
pleasse need help fast :)
i tryed starting it with jumper leads it done the same thing?
sounds like you need a relay in your starter solenoid.
have a search around, been covered a bit.
basically you need to wire a relay into your starter solenoid wire, as there is too much voltage drop through the 30yr old wires running around your car.
how could that problem occour?
last time i turned the key it started first go
its been in the garage for a about about a month as i ive been working on it
now it just wont turn over?
well yo need to start with the diagnosis....
make sure your battery is good, or put a known good one in.
then if it still wont go, you need to look into the wiring. you can use a peice of wire straight from the battery to the starter motor solenoid. if that works then you know its a wiring issue.
just tryed the battery out of my brothers car done the same thing.
ill try putting a wire straight to the starter motor.
thanks for your help bud
il post my progress
Could also be the 30 year old ignition switch,but sounds more like your soliniod on the starter.Tryed shorting across the terminals
see if turns over.
Broken wire??and yes a relay on the starter works very well,more so if your battery is in the boot.
rob
Starter motor is stuffed, if the solenoid is clicking and there is no rotation, common sign of a dead starter.
A relay is a band aid fix for a dying starter, the older they get the more voltage they require and if wiring was failing because it was old then everything in your car would be failing.
Sounds better.
But also the solenoid needs way less amps to switch on then what it takes for the starter to even think about winding over.
