Ok so it misses on start up and goes away after 2-3 mins.
Likly to be related to the vehicle after you have turned it off the day before.
For example leaking injectors will cause a miss once the car is started because of the excess fuel in the combustion chamber.
Also cracked head or head gasket problem is related to car being warm then sitting after.
Coolant will leak into the combustion chamber until the engine heats up and the engine components expand and stop the leak.
Electrical problems can also be heat related due the the metal components that expand and retract so water temp sensor is a possibility as the ecu might be overfuelling the engine which will cause a miss until the motor warms up.
There you go a heap of stuff for you to check on.
thanks slot of that:), but evan if ive had it going for 20-30 mins then shut it off for 2 seconds and start it it will still miss for a few minutes? ill see if dad can give me a hand:) thanks again mate
I had intentions of helping, until you and your vast knowledge at 16 began to shut the people helping you down...
Such as your comment, "Doubt it..." Why exactly did you doubt the temp sensor? Seems like a prime suspect to me, going off what you said about the symptoms. Please explain why that suggestion wasn't worth pursuing? Come one, I'm waiting.
You are the one shutting people down and wasting their time, I can assure you of that. Personally, if I just spent $700 servicing a car and got it back doing that, Id be straight down there to see what the f@$k they did to it and make them fix it.
Help yourself. Try things, or if you'd rather stop wasting your time you could get it to a scan tool.
Thats all the help you need.
You come to a TOYOTA forum with questions about a FORD, 'nuff said. I'm with LittleRedSpirit. :y:
i have a toyota ya douche, i just asked a question about my falcoon
  • Downvote 1
:laff:
take it back to your mechanic that wasted your $1000. lol man up.
na it was doing it when i bought it the guy i got it from said it was a sensor but I'm not sure
now i remember why i left this forum :l
TWF#14, you mean you were banned from this forum multiple times, under multiple user names.
Go join a Ford forum.
