Vehicle: Jdm Evo VII
Engine:
Manley 100mm stroker crank shaft (2310cc)
Manley H beam conrods
Manley 20thou over Forged pistons
Brian Crower 272/272 camshafts
Brian Crower Adjustable cam gears
Arp Main stud kit
Arp Head stud Kit
Acl race series bearings
Acl race series MLS head gasket
Mild head port
Bolt ons:
S/S 3" TBE
1000cc injectors
Walbro upgrade intank
Plazmaman hotside kit
Plazmaman air fiter intake pipe, K&N filter
GTpumps 76HTA 1.5bar actuator
Driveline:
Jim Berry custom 3300lb 6puck Carbon clutch
Lightened Flywheel
Suspension:
Tein Adjustable Coilovers
ICE:
a radio of some description
Tuned by:
Forced Fed Performance and Tuning
Performance:(standard motor)
98 Ron Power: 203kw
98 Ron ET: Yet to 1/4mile
E85 Power: (Estimate) 240+KW
E85 ET: 12.19@109mph
Stroker motor
Power: 322kw @ wheels
ET: 11.911 @ 120.5 (jamboree 2011)
Standard 98 RON (full TBE) reflashed ecu
Edited by OKE055
7 is the best :D
+ 1. i don't really like Mitsubishi's that much but Evo 7's hit the right spot. can't wait to see a time from the stroked motor.
Just a quick update got some parts back last week and starting to reassemble the big girl.
Edited by OKE055
jesus christ that engines going to be overrated! haha, your going to have a ahh, 'fun' time running in the motor ;) Its a good thing its 4WD!!
I remember my dad running in his motor, and his run in tune was 340rwkw@3psi...
Those GT Pump 10.8 Turbos with the Plazmamann hot pipes work wonders,
even the standard ECU flashed with EVOscan/ECUflash get some much tuning out of them
takes nifty jappas to design the ECU, and a kiwi guy to crack it haha
nice work tho, i wonder if you will twitch for the APC Banshee motor (2.4L) haha
Edited by NISROLA
Just a quick update got a heap done this week basically a little work to do in the morning and ill be firing her up!
Heres some progress pics.
Jim Berry 3300Lb Clutch
A pic of the cooler "Black" stealthed out
Not that itll make it look sleeper though alot of people make an effort to look at the front of the car to see if it has a cooler.
Edited by OKE055
Man, i just did a ke70 4K replacement, and i cannot even start to fathom the intensities of not only having to deal with a decent size wiring loom but also a turbo and plumbing, and cv joints and the list goes on
good work mate
