May 23, 201115 yr comment_526300 hey do 4age main studs fit 4k mains i heard a rumour about this.. and is there anything for rod bolts? Report
May 23, 201115 yr comment_526371 Mitch..... you really need to learn how to use the search function. :yes: Report
May 24, 201115 yr comment_526384 hey do 4age main studs fit 4k mains i heard a rumour about this.. and is there anything for rod bolts? Rod bolts wouldn't bother Mitch. By the time you prep em(even working in the industy) should end up same if not dearer than buying spool rods. I've got a 4age and a couple of "k's" at home so in the next couple of days I'll try a 4age bolt in my 5k and let you know. Stu. Report
May 24, 201115 yr Author comment_526463 i used it taz couldn't find anything and that would be sweet mate if you could i read on another forum that 4age arp mains fit 4k mains thanks mate Report
May 24, 201115 yr comment_526465 Ummm, why bother. A standard 5K bottom end will handle 8000rpm (plus at times :o ) without complaining. Wasn't there something about using Chev V8 rod bolts at some stage??? Report
May 24, 201115 yr Author comment_526468 it's boosted so there is fair bit more pressure on the mains Report
May 24, 201115 yr comment_526550 the 4ge main studs do fit, but you have to cut the stud beside the oil pump from memory. the ARP small block chev bolts will fit the3/4/5k con rods only if you ream the hole out to 3/8th hope this helps Edited May 24, 201115 yr by trd Report
May 24, 201115 yr Author comment_526570 does anyone have the part numbers that fit I'm not sure if there are multiple part numbers that fit different 4age mains Report
