January 21, 201214 yr Author comment_579326 Well it's only about -6ºC now so its not that bad :P Report
January 21, 201214 yr comment_579343 Never been in snow before :P but its on the list " to do before I die " list ! Report
January 21, 201214 yr Author comment_579347 It's just so easy to have fun in the snow :) You really should try it someday. Report
February 2, 201214 yr Author comment_581829 It's been freaking cold here for a few days now. It's currently about -27 degrees. I had the Corolla parked at work for a few days and on wednesday i had to start it in -22 degrees to get home. And as i've written it's notably hard to get going when cold but the battery stood with me for quite a while. I was expecting it to be completely dead at a few turn overs but it wasn't :) Nonetheless it wasn't enough and it finally gave up but we had other company cars (2010 Hiace) around and some jumper cables so then it hopped back to life :) Was also funny when it first started and i let go of the clutch it stopped cause of the heavy resistance of it alone :D Poor 4K's :rolls: Report
February 2, 201214 yr comment_581843 Have you got around to checking the points gap & timing? It might fire up easier with a bit more advance, the 4K seems to run quite happily with 10 or 12deg advance. I suppose you will be up for different grades of oil for summer and winter in the motor and gearbox, like the tyres.... Report
February 3, 201214 yr Author comment_581945 My dad who understands the points gap stuff a bit more did set it up somewhat before winter time, but it's probably not perfect. I'm running semi-synthetic 10W-40 oil in the engine, was mainly bought cause it was cheap.I haven't touched the gearbox oil so god knows what's in there :D But it shifts without any problems and if it works in -25 degrees what more can you ask. Report
July 17, 201214 yr Author comment_616045 Hello again. Took some pictures today as i washed the car so i'll put them up here :) Not driving the car now during summertime cause i have the other car for that, so the Corolla just stands still. I'm gonna put some wax on it today so it doesn't look totally horrible from all the leafs and whatnot that get stuck on it. Engine and everything is running tip top as far as i can tell. I start it once in a while and drive a few kilometers to keep everything going. I still don't know what to do with the car if i'm gonna spend some cash on it or just leave it stock. Winter tires on in July! :D Edited July 17, 201214 yr by Tomas_90 Report
July 17, 201214 yr Author comment_616082 I'll add a few more since i was waxing it this evening :) I'm still gonna clean the interior some more but that'll be some other day. It is fairly decent but nowhere near perfect. Edited July 17, 201214 yr by Tomas_90 Report
