October 15, 201115 yr comment_560505 Hi All, Couldn't find any other threads on this so thought I might start a thread with a run down of how to remove and install/replace a dash pad from a KE30 (edit: my car is a late KE30 which means it's the same as a KE55 Dash) because it can be a real b!tch. Sorry it's a bit long Time to remove: approx 1.5 hrs Time to install: approx 1hr But it will vary depending on your dexterity & care taken (I tend to be a bit slow so more than likely times will be less) You'll need: Ratchet 10mm socket 12mm deep socket 2 x phillips head screw driver (one stubby) Patience (Optional) torch flex ratchet extension + Phillips head driver little dental mirror thingy You might be able to skip some steps like removing the radio and it's light but to be honest it takes two seconds and it'll save you a world of pain. I also figured I would undo the hidden screws last for removal and for installation put them in first as the dash is loose and it's easier to get the screws in/out when you can jiggle the dash about. REMOVAL Step 1: Remove Glove Box Remove screws and latches as shown: Gently pop out the glove box. They're made out of flimsy flocked egg cartons so it doesn't take much to wreck it. If you push upwards underneath at the rear of the glove box it should come fairly easily. After you've removed the glove box here's what's left to unscrew: Step 2: Remove remaining visible screws (red) on dash Step 3: Remove instrument panel fascia Pull off radio knobs (4 parts total) and use the12mm deep socket to undo the two thin hex nuts & gently push out fascia. Disconnect the cigarette lighter and remove the fascia. Step 4: Remove radio & hex nuts (blue) Remove the 3 Radio bracket screws (see above pic), disconnect the radio andremove it. Dismount the light above the radio, it should pop out and give you better access to the hex nut behind it. Remove hex nuts. Step 5: Remove 2 hidden screws (yellow) You will need either the stubby phillips or the flex extension + phillips head driver + ratchet or both. Make sure you use the correct size Phillips head because these are self tappers into plastic and are super tight. Also make sure you're undoing them because it's easy to get jumbled when you're unscrewing from the otherside! The screw near the cigarette lighter shouldn't be too bad, if you put your head in the foot well it's easily visible. Here's where it's located (dash already removed in pic): The screw behind the passenger air vent is the real killer. Make sure you're undoing the screw inthe middle. The two either side are for the air passage and in mine were even harder to remove and irrelevant so I didn't waste time on them. But if you're feeling adventurous and you can get them undone it might be worthwhile removing the air channel so you have more room. Step 6: Remove dash pad (YAY!) INSTALLATION: Pretty much reverse of removal with some additional steps: Step 1: Install hidden screws To make things a little easier I screwed in these 2 screws all the way into their positions once without the dash in place to remove a bit more of the plastic. My screws were really tight and even after doing this they were still plenty tight. If yours is loose you don't need to bother. Put dash pad roughly into position and install hidden screws Continually check the tightness of your nuts/screws as you go as they will have more room to screw in as you gradually align the dash to the rest of the car. It also means you can minimise any annoying rattles/creaks from loose parts. Step 2: Install Hex nuts, radio light and radio Step 3: Install instrument panel fascia Step 4: Install remaining screws Step 5: Install glove box Latch: (Step 6 only if replacing dash): Gloat about your dash. DONE! Edited October 18, 201115 yr by soyboy Report
October 15, 201115 yr comment_560514 Brilliant write up mate, one for the FAQ i reckon. Nicely done! Report
October 15, 201115 yr comment_560547 Late '30 and as towe001 said '55 dash indeed a good write up Edited October 21, 201610 yr by DZach23 Report
October 17, 201115 yr comment_560986 Great Write up Sonya, You wouldn't happen to know the best way to remove the entire dash is would you? (ie what screws you can leave in, just remove xzy screws from the firewall?..ect..) Thanks SatNav Report
October 18, 201115 yr Author comment_561090 thanks guys, didn't know it was the same as a KE55! I edited the OP> Sorry SatNav, haven't had to take the whole dash out so unfortunately can't give you any pointers on that. Report
October 23, 20169 yr comment_706687 Yes it was a very helpful thread before the links broke. I used it also! However given the age of the thread and the dropbox used I'd say you're out of luck. Shame though. Report
