I keep hearing everyone recommending ARP head bolts. What makes them so special?
Cheers Ray.
WWWAAAAYYYY better material to start with and they are the same diameter all the down the stud.
stu.
  • Upvote 1
Ive been told the 4age long bolt in arp match the K series ones
but you need 2 sets. Usually ARP can be contacted and they will
supply then all the same length but don't know the price or sizes.
Also the fact that they are a stud you are applying a force to the thread in the block but to the stud itself.
The force or tension in the bolt/stud etc is the same throughout the bolt/stud, and is also the same force that the thread must withstand. since its all joined together.
i think bolt stretch is the big thing with ARP head bolts,
there is some good information on their website, fairly vague. but gives you a good idea.
http://arp-bolts.com/pages/technical_design.shtml
if you click on "technical" there is some more pages.
Yep that's right. Pretty sure part numbers I have are for 4age long studs. I got a price through my wholesale supplier at $260. Which is a lot dearer than Mitch-12's and boostedk's group buy prices.
Is this for a boosted or big compression "K"? If not it's not a real necessity for them.
Stu.
Under a liteace or townace it seems the extra heat can cause issues with the
headgasket more than rollas, not to mention soften heads. Re-tightening H/bolts
every 10,000klms helps but I always think arp head bolts are a good investment
if you are keeping the engine for its life.
For my low km 5k liteace I'm getting a twin port ex manifold and outlets coated
by HPC to help with lowering the temps but might need ARP headbolts also.
In your case I'd probably use them myself.
HPC will help in your situation a heap too!!!
Also are you using genuine Toyota head gaskets? From memory are around $50. Do you have a measurement of the head top to bottom(mine has been savagely milled)
Reason I ask is that(and Mitch can you confirm this) with my milled 5k head I'd have to use 2 washers as the studs are a bit longer than the factory bolt.
Stu.
Edited by kickn5k
If you have ever fitted them then you would know what I mean.
When installing head bolts you are applying a twisting as well as an upwards motion to the thread, this can damage the threads (like trying to put a bolt into an exhaust on an aluminum head instead of a stud), by installing a stud the breaking force is applied to the stud which is why they are screwed in finger tight.
Stu.
yeah with any 5k head you need 2 washers and you could use 2 with 4k also but it seems to just make it with 1 washer
