Sorry guys havent been around much
You are correct the plate isnt tapered,it has its own bolt pattern so.I'm gusding the manifold wss just designed for that pattern in a short run
The other end is standsrd weber pattern
I highly reccomend any alternator other than lancer.....they are not rebuildable as i have found out
It was all custom brackets anyway mate,its got an old mazda one on it now 323 i think
The engine mounts are pretty straight forward,we just sat the motor on timber on the crossmember,slit the long mount and bent it down to the correct angle,extended it and gussted it with plate
The other side we just cut a section out to shorten it
The gearbox crossmember is standard just spaced one side off the box and the rubber takes up the rest
  • 9 months later...
