November 5, 201114 yr comment_564587 Hey all prob a stupid question but i got a ke30 4k carby and i can start the vehicle but wen i release the key back to on it dies So i have to keep the keep the key turned to start to keep the car idling Can anyone help Any thoughts Ignition Switch?? Thanks Report
November 5, 201114 yr comment_564590 Wiring- The "start" position is one set of wires and the "on" position is another set. If the carb has an electric fuel cutoff you may not have that connected. Otherwise, power is not getting to the coil when the key is "on".. Report
November 6, 201114 yr comment_564603 did you check your ignition fuse/relay? check for 12v at the coil/ fuel solenid and report back with findings Report
November 6, 201114 yr comment_564611 I'd put money on it being the ballast resistor (the white rectangle that sits next to your coil pack) $3 from repco Report
