shayden Posted January 7, 2012 Report Share Posted January 7, 2012 hey all gna be puttin my motor into my e7 soon and jus wanna get a few tips on how to run it in.. mods are: light head work bigport possibly ITB's 264 in. 272 ex. custome valves (3sge) springs 7a block gze slugs custom rods t25 or 28 turbo any advice on choice of cams will be great aswel thanks :) Quote Link to comment Share on other sites More sharing options...
oh what a nissan feeling! Posted January 8, 2012 Report Share Posted January 8, 2012 Run in should be done under high load, and without using the redline end of you rev range. Eg. A good mountain run using higher gears at lower revs on the hill climbs, try to really labour the engine. Quote Link to comment Share on other sites More sharing options...
Twinky Posted January 8, 2012 Report Share Posted January 8, 2012 Something interesting on running in engines. http://www.pumaracing.co.uk/runin.htm 1 Quote Link to comment Share on other sites More sharing options...
Evan G Posted January 8, 2012 Report Share Posted January 8, 2012 http://www.rollaclub.com/board/topic/42018-how-to-wear-in-my-4k/page__hl__%2Bbedding+%2Bin__st__30 there you go Quote Link to comment Share on other sites More sharing options...
shayden Posted January 8, 2012 Author Report Share Posted January 8, 2012 Thanks for the links guys, and oh what a nissan feeling i thort ur nor ment to put much load on a new motor sumthin to do with the rings ? Thanks Quote Link to comment Share on other sites More sharing options...
Sephiroth Posted January 8, 2012 Report Share Posted January 8, 2012 Thanks for the links guys, and oh what a nissan feeling i thort ur nor ment to put much load on a new motor sumthin to do with the rings ? Thanks Your supposed to load it up so the rings don't put a mirror finish on your brand new scored bores the grooves from bore honing hold oil on the walls which obviously helps lubricate them if they were smooth the rings would work like a squeegee So like oh what a Nissan feeling said load her up a hill it's what we do with our engines at work Quote Link to comment Share on other sites More sharing options...
shayden Posted January 8, 2012 Author Report Share Posted January 8, 2012 oh kk thanks for all the help and info guys cheers :) Quote Link to comment Share on other sites More sharing options...
Trev Posted January 8, 2012 Report Share Posted January 8, 2012 The problem you are going to face right off the bat is that you have an engine with no tune so it will need to be tuned before you can do anything with it but this also comes with a positive, the dyno tuner will lightly tune the engine to 4000 - 5000rpm and will do most of the run in on the dyno for you, you will then be required to drive it around for approx 1000km to let the engine settle in and then take it back to have it tuned to make power. When I build an engine I generally keep it under 4000rpm, try to labour the engine as much as possible and keep it off boost, a few pound won't hurt but don't go giving it to it. Also to mention, new cams will need to be run in, who is building the engine? As for cam choice, I was going to buy HKS shafts but I have recently been looking at these: http://www.ebay.com.au/itm/JASMA-Camshaft-264-272Deg-Levin-Trueno-4AGE-4AGZE-16V-Stage-2-/120774641075?pt=AU_Car_Parts_Accessories&hash=item1c1ebac5b3#ht_2361wt_952 Quote Link to comment Share on other sites More sharing options...
shayden Posted January 8, 2012 Author Report Share Posted January 8, 2012 The problem you are going to face right off the bat is that you have an engine with no tune so it will need to be tuned before you can do anything with it but this also comes with a positive, the dyno tuner will lightly tune the engine to 4000 - 5000rpm and will do most of the run in on the dyno for you, you will then be required to drive it around for approx 1000km to let the engine settle in and then take it back to have it tuned to make power. When I build an engine I generally keep it under 4000rpm, try to labour the engine as much as possible and keep it off boost, a few pound won't hurt but don't go giving it to it. Also to mention, new cams will need to be run in, who is building the engine? As for cam choice, I was going to buy HKS shafts but I have recently been looking at these: http://www.ebay.com.au/itm/JASMA-Camshaft-264-272Deg-Levin-Trueno-4AGE-4AGZE-16V-Stage-2-/120774641075?pt=AU_Car_Parts_Accessories&hash=item1c1ebac5b3#ht_2361wt_952 I'm gettin footscray eng. recon. to do the port polish n all the tricky bits, but I'm gan do the rest... ect. put it back together. as for tune ima run megasquirt v3 and hopefully ill make it to the workshop to get tuned, running t50 n standard diff lol. with those cams can u really trust the name? thanks Quote Link to comment Share on other sites More sharing options...
Trev Posted January 8, 2012 Report Share Posted January 8, 2012 I'm gettin footscray eng. recon. to do the port polish n all the tricky bits, but I'm gan do the rest... ect. put it back together. as for tune ima run megasquirt v3 and hopefully ill make it to the workshop to get tuned, running t50 n standard diff lol. with those cams can u really trust the name? thanks So you are going to try to drive it untuned? JASMA? why not, I have one of their turbo manifolds and the work is very impressive, sure if you have $1000 to spend on cams then get some HKS shafts. Before anyone says 'but JASMA is an exhaust regulation' I am talking about JASMA and not JASMA Quote Link to comment Share on other sites More sharing options...
shayden Posted January 9, 2012 Author Report Share Posted January 9, 2012 So you are going to try to drive it untuned? JASMA? why not, I have one of their turbo manifolds and the work is very impressive, sure if you have $1000 to spend on cams then get some HKS shafts. Before anyone says 'but JASMA is an exhaust regulation' I am talking about JASMA and not JASMA arrh kk righto, jus neva really heard bout them before but it was talkin to the guy doin my motor n he rekons there ok aswel so mite get there cams.. and ima try tune it best i can at home den drive it to chasers to get it done.. Quote Link to comment Share on other sites More sharing options...
Trev Posted January 9, 2012 Report Share Posted January 9, 2012 arrh kk righto, jus neva really heard bout them before but it was talkin to the guy doin my motor n he rekons there ok aswel so mite get there cams.. and ima try tune it best i can at home den drive it to chasers to get it done.. After spending that much money I would be just getting it towed and leave it all up to the tuner to do. 1 Quote Link to comment Share on other sites More sharing options...
GJM85 Posted January 9, 2012 Report Share Posted January 9, 2012 first gear, top end, 30 pounds, through a lake.... :cool: Quote Link to comment Share on other sites More sharing options...
shayden Posted January 9, 2012 Author Report Share Posted January 9, 2012 first gear, top end, 30 pounds, through a lake.... :cool: lol what ? Quote Link to comment Share on other sites More sharing options...
kryton brown Posted January 10, 2012 Report Share Posted January 10, 2012 http://www.mototuneusa.com/break_in_secrets.htm This is another site that desribes similar methods to the one above. Running an engine in under load is not a crazy concept. Quote Link to comment Share on other sites More sharing options...
