Hi I'm putting s tacho into my ke70 and I'm just wondering if any tacho will work? I'm looking at an auto meter sport comp but it has a whole bunch of wires but I thought only like 3 or 4 wires were needed? Earth, accessories and the "signal" that actually tells the tacho the revs (don't know if it's actually called the signal but yea).
If I'm correct all of those wires are already at the back of the dash ie. I don't need to run new wires do I?
yeah the wires are at the back.
to run an aftermarket tacho i belive you will need the following:
-ignition +12V
-Ground (bolt to chassis somewhere, or piggy back of something else)
-dash lights +12, piggy back off something else for this
-signal - this is a single wire, that eventually connects directly to the negative side of the coil. there is a multi pin plug in the back of the ke70 dash which has this already, but i can't recall which one it is...it might be written on the circuit board of the dash cluster, or you might have to get out the multi meter. note, the aftermarket tacho may come with a heap of signal wires, this is for if you have multiple coils, but the ke70 only has 1 coil.
Thanks Dave I did find a tech thing on here which explains what wires do that's fine. You have answered my question well, cheers
