Hey guys!
just curious on throwing in a v6 cressida engine in my ke 55... cheap enough so i thought why not... sooooo a few questions if i may.
Is it possible? with minimal effort? has anyone considered it?
any one know anything bout trannys? if the ke55 will fit on?
please
anyone with answers or any kind of help is a mad kent
Cheers fellas
Nik
lol Evan.. you mean this problem-
The Avalon was a front-wheel drive full-size car, powered by a V6 engine, as the third-generation Camry remained in the mid-market but now had grown in proportions to be classified as a mid-size. The Cressida was an upper-level mid-size rear-wheel drive car with a straight-6 engine
Nik, there are several Holden V6 motors in Corollas on here, but turning the Camry motor around would be a pain.
I'm not sure I'm following altezza, (sorry i don't know how to quote)
what do you mean camry motor? and my bad i knew it was a straight 6 just the 'v' was habit haha
i figured it would be doable seeing as its a small 6, and rear wheel drive.
and evan... haha i don't know what a 1uz is :$
plan was to get cheap injected 4 cylinder engine with minimal hassle of installing (ie tranny/shaft/ mounts)
but i saw this engine n thought maybe it would be easier.
insight?
cheers guys :)
Answers to your questions:
Is it possible? Yes
with minimal effort? No
has anyone considered it? Not that I know of. For the work to get a 6 in then you might as well put a decent one in. M series motors often send a shudder down people's spine, there's a reason they are cheap.
any one know anything bout trannys? Only what I've accidentally discovered from google searches. I prefer women with womanly bits, I'm certain i saw one walk into the maccas in St Kilda once.
if the ke55 will fit on? No.
anyone with answers or any kind of help is a mad kent. Don't say "mad kent", it makes you sound like an idiot.
1uz is the Toyota v8. It would be cooler than the Cressida motor but likely a fair bit of effort involved. Pmp020 has experience with ke20s with bot a valiant 6 and an rb30 if I recall.
Edited by philbey
Ah. OK, the straight six. They carry an inherent problem of being longer than a 4cyl, so put more weight over the front axle & upset the balance of the car.
That makes it harder to get the best handling for corners, but f you're into drags it probably helps.
Almost ANY motor with much more power will need a complete change of drivetrain, clutch, gearbox, driveshaft, diff.. the lot- and nothing bolts up to a K motor except a K gearbox as far as I know.
How about the 4Y motor?? 4cyl 2.2L, made up to the early '90s and out of the Hi-Ace vans. If you're looking for easy torque that will be a simpler conversion than the straight 6, and the motor is still basically a big K engine..
haha thanks everyone! ill sus out the conversions for the 4y motors and see what i can find.
and thanks for steering me away from that horrible idea of putting the cressida motor in, much appreciated
will also keep the 'mad kents' to a minimum.
haha that video is awesome! i semi shit myself when it took off haha
thanks again guys.
Nik
