agius Posted May 2, 2012 Report Share Posted May 2, 2012 hey guys i just started striping one of my 3t's and the bores don't look to great defiantly needs a re-bore I'm just after standard compression oversize pistons and i know both the 3t and 2t have 85mm bores standard so does this mean they both take the same pistons? theres alot of "2t" pistons available on ebay and not many "3t" thats the reason why I'm asking.. thanks in advance :) Quote Link to comment Share on other sites More sharing options...
Evan G Posted May 2, 2012 Report Share Posted May 2, 2012 2T-C bore 85 stroke 70 3T-C bore 85 stroke 78 ebay usa maybe? i can get them thru my engine builder if you need? ill give you a buzz next time I'm down Quote Link to comment Share on other sites More sharing options...
styler Posted May 2, 2012 Report Share Posted May 2, 2012 No the pin height is way different to compensate for the stroke of the crank, 2t pistons on 3tc would poke out the bores and smash the head if installed. Quote Link to comment Share on other sites More sharing options...
styler Posted May 2, 2012 Report Share Posted May 2, 2012 1) 2t crank + 2t pistons 2) 3t crank + 3t pistons Quote Link to comment Share on other sites More sharing options...
agius Posted May 2, 2012 Author Report Share Posted May 2, 2012 No the pin height is way different to compensate for the stroke of the crank, 2t pistons on 3tc would poke out the bores and smash the head if installed. Fark, 3t pistons it is then.. Thanks for the info man :) Quote Link to comment Share on other sites More sharing options...
tojo2 Posted May 2, 2012 Report Share Posted May 2, 2012 "rockauto " is cheap and got most of 3T parts Quote Link to comment Share on other sites More sharing options...
agius Posted May 3, 2012 Author Report Share Posted May 3, 2012 "rockauto " is cheap and got most of 3T parts thanks tojo u been a massive help with all my problems :) Quote Link to comment Share on other sites More sharing options...
