Pretty sure all the wiring/plugs is totally different.
Plugs are the same, wiring is different.
All you do, pull your cluster out, then copy the wiring diagram that's in that Toymods thread, you need to change it so your wires are the same as ADM KE70, it's fairly straight forward, the wires just unclip and you clip them into the new plug position. Did it in my panelvan but i couldn't get the factory water temp gauge to work which isn't a big deal.
Should only take a hours
yea i thought you had to as the panel van doesn't have the tacho signal. I guess i just have to trace back from the tacho to what plug it is or do you remember?
did it today every thing works expect dash lights but ill fix that. sadly i shorted out the clock some how so got to find another one or fix it depending on what blow. that guide worked great. there where just couple wire that weren't the same. tacho works I'm going to check it some time soon to see if its accurate
  • 10 months later...
Site is back up - interwebz won't allow me to download the file.
If someone has a copy and could email it to me that would be great...
