July 9, 201214 yr comment_614273 whats the easiest way to get 5 stud falcon pattern under the front of a ke55? so basically,what struts and brakes do i need? Report
July 9, 201214 yr comment_614282 Well i guess just put falcon struts in.. Geometry could be shit as fark though. Report
July 9, 201214 yr comment_614312 ill give you the most simpliest answer. xt130 struts ms65 hubs. 5X114.3 Report
July 9, 201214 yr comment_614324 Weld hubs and re-drill, done it before. Ill find a pic for ya. But, then you need to sort out brakes etc, complete strut conversion prolly simpler. A crude comparison, but you get the idea... Edited July 9, 201214 yr by ae824ate Report
July 9, 201214 yr Author comment_614343 Well ill ask why?? because i want to Well i guess just put falcon struts in.. Geometry could be shit as fark though. not gonna happen ill give you the most simpliest answer. xt130 struts ms65 hubs. 5X114.3 thanks,thats what i thought i had read,what calipers fit? Weld hubs and re-drill, done it before. Ill find a pic for ya. But, then you need to sort out brakes etc, complete strut conversion prolly simpler. A crude comparison, but you get the idea... it will be a cold day in hell before i do that! Report
May 10, 20188 yr comment_714461 hi there moot how did you end up going with the conversion. i want to do the same conversion to ford stud pattern in my ke rolla due to running a shortened au falcon diff. its a burnout car so nothing has to be special cheers Report
