hey, i have a ke70 wagon that i put my old track cars running gear in. was all good had it running for ages then picked up a low km 4age chucked it in the other day and now it cranks but no spark and fuel pump is not priming.
any help would be great! :)
Did u check that fuel pumps are gettin 12v during cranking?
Stock Toyota's don't "prime" the fuel pumps when u turn to ign, they run on crank and then run for extra couple of seconds after cranking if engine doesn't fire.
Get wiring diagrams and diagnose.
  • 5 weeks later...
sounds like a wiring issue, get a pro out to look at it if you have no clue, also it shouldnt be a fuel pump issue etc because you were running the same one prior to the new motor right ?. try and see if your fuel lines are in the right way (in + out) try diagnose the problem first, when you crank it open the in fuel line see if its getting fuel, if thats the case thats not the issue, then check your spark, and so on. :) is it the same ecu ? or ?
