I hope this is in the right place to ask
I purchased a 3sge G1 beams. It has the ecu ,but does not have the AFM.
Will an afm from other toyotas work with engine.
If yes what model will suit or even be an upgrade(if afm are upgraded) :P
  • Replies 51
Thanks for links Nick,But didnt find any solution there.
Your idea of geting rid of the hotwire and using a map sensor requires a stand alone that will also run the dual vvti which means alot of money especially since I have the stock ecu. :P
Edited by canon
Its rear wheel drive type so it from the altezza
And it had this header fitted on it.
don't know what other goodies it has inside?????????? :D
It tags on it one says JASMA and the other 5Zigen
ok afm for 3s-ge with vvt-i part no,s 22204-21010
also fits prius- 1nzfxe
lexus rx300-1mzfe
camry-1azfe-2azfe
4 runner-5vzfe
landcruiser-5vzfe
prado-5vzfe
kluger-1mzfe
surf-5vzfe
apexi do a aftermarket pod unit that takes this type of afm, i used one for a 1zzfe-turbo converrsion
hope this helps
TRD Thank you :D
This is a relief because altezza parts are rare at used parts importers and the dealers never sold altezza in this part of the world.
Found this mystery item atached to one of the fuel lines wonder how many Hp it adds
has any one done a direct comparison ie. dyno before and after with one of those fuel saver thingy's?
everyone rights them off, me included, but the results would be interesting
Nice :D
And forgive me for the late welcome :locked:
So the 3rd pic is the only point of rust throughout the whole vehicle?
If so.. that's childs play for a rolla :) Easy repair
